Scaling with analogue cards
Spj
Oct 2015
Manteca
We have a cooling line with multiple vfd's banked in groups in panel. All functioning well but a set of four which seem to to vary in speed in unison. When attempting to fix them by looking at scale they look good. But after a while they drop in hertz. When changing parameters not much changes?! What do you guys think? PID?
+1 For using bus.
Do you use a single analogue output to all drives in series? Maybe your analog output is not "powerful" enough? Perhaps you could try galvanic isolator. Or perhaps use the analog output option many drives have to send signal to second drive?
Thank you for your input guys
Boss ended up buying a new card, problem solved. I was trying to see if there was something I was missing. Production is not a friend of lengthy fixes so we will see. I am very appreciative of your time and knowledge, later guys
376
Hello guys I am just wondering do I need to set up each channel configuration, including enabling the channel , ranging … if I have already...
2,024
There have been a number of posts asking about scaling so I thought this may help. The formula is: Out := ((Variable_In - ZeroIn) / (SpanIn -...
6,568
Hi, I have an application with a load cell where I need to log the load cell output, into a small/internal data logger. But I also want the...
1,723
Hello there I am having trouble scaling my analogue input signals. If I use engineering units and use the RAW scale as 4000-20000 everything is...
2,627
