Scaling
acerbic
Nov 2008
cardiff
Hi everyone...
I am bit struck so thought to get a little help from u guys...
I am bit confused which function shall i use to scale something from 0-100%...
Tph FEO COil Actual FEO
1000 10% 10%
500 5% 10%
This is short example to make life bit easier as u all can see above FEO COil % decreased to 5 % whereas Actual FEO is 10%
It Shouldnt goto 5% and stay at 10%
If someone could help me out with this please what function shall i use to make some logic...
regards
Adi
I have everything set up for vibration monitoring with the code in Controllogix 5000. The thing is that I am not able to read values SCADA in mm/s...
29
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
198
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
700
416
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
232
