scaling
cool
Feb 2011
Perth
Hi all,
I have limmited programing ability and need help to setup a counter with scaling.
for example each input from X 1 needs to be multiplied by 2.55 and then placed into D 1.
I use mitsubishi FX PLC's
I don't know mitsubishi at all, but i would just let the counter count, and multiply its accumulator value by 2.55, depositing the result in D1
Count=0 D1=0
Count=1 D1=2.55
Count=2 D1=5.1
etc.
D1 would need to be a floating point register, or you will get
Count=0 D1=0
Count=1 D1=3
Count=2 D1=5
Count=3 D1=8
Count=4 D1=10
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
149
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
619
363
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
219
Hi all. I'm working on a rehab and I'm trying to figure stuff out. See screenshot at the bottom. Local:5:I.Data[6] in BTD instruction is a...
714
