ScanPro to Powerflex 70
Oct 2007
TN
Does anyone know what parameters I have to set in a Powerflex 70
so that the scanport card can control it. This is an upgrade so
the PLC programming is in place, but the Powerflex 70 is an upgrade. Thanks, Any info will be helpful.
I believe that you have set set your start/stop source and speed source to DPI port 2
par 90 Ref Sel A - DPI port 2
par 361 Dig In 1 - 0
par 362 Dig In 2 - 0
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
173
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
275
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
176
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
236
