FYI
I was thinking about what i remember about the machine, they ran of steppers instead of servos. You probably want to do a lot of research before you decide on that peice of equipment. The gripper has two fingers and only two motions (roll and pitch). Dont quote me but i think this machine had 4 relay outputs too. The functionality of the software is amazing but when you put it to work, it would just not work the way it was supposed to.
The other one i spoke about earlier was called the MENTOR ROBOT. I dont know if the company is still around. They were made in UK and used soemthig called WALLI programming. The reach on this one too is close to 17".Very strudy equipment. As I said, heavy but i dont know what your application is. This too has two fingers and two degrees of freedom. Has servo motors and feedback was through potentiometers. Cost like 7000 a peice over 3 years back. Has 8 digital inputs and 8 outputs and 4 analog inputs
