Epson T3 Scara Ethernet/IP with Logix 5000
phuz
Jun 2008
Mohnton, PA
1,044
Does anyone have any expertise with communication between a Logix PLC and an Epson T3 Scara robot? I have an Ethernet/IP slave fieldbus board installed, and it shows correctly in the Epson RC+ 7 config, but when I added the 1756-MODULE for 32 bytes in/out instances of 100 and 150 for the input/output, I get no data. I'm assuming I have to somehow map the I/O from the default bits to the fieldbus bits.
Epson's documentation isn't great.
I am connected to a G6 through EIP to an RC700. I am in the middle of something right now but will post something later.
Keith
Looks like I was able to change the Remote I/O bits and made some progress. I'm getting a little more involved with it now with trying to define programs. I had not changed the control device to Remote I/O which is why my commands weren't being recognized.
HI
Just to add as per the_msp post it was me who asked the question back in 2002.
I have found the code for that robot and if you send me a pm I could send you the epson code
Donnchadh
Hi, Based on the eds file given from Epson, when added in a robot device in the IO tree, with 32 bytes of input and 32 bytes of output, the...
1,193
I am trying to print data from a compactlogix PLC to an Epson ticket printer. I am using a RTA Ethernet to serial (ASCII) converter to connect...
1,855
Hello everyone! I have an Epson RC170 that is communicating with a SLC 5/05 over DeviceNet and working great. We are attempting to upgrade the...
1,720
Getting an internal error after "On Home_Complete" line. Program continues normally after selecting ok on the information pop-up. Full message...
1,720
i have F 940 Got Hmi and epson printer connected to via LPT port. Now the wire form connector of the printer side has been dismantled and i am...
1,884
