Schematics for S7 MPI cable
Hello :
could you help me :
I have CPU313C-2DP , I want to connect it to the OP73 by MPI cable .
when I' ve download project to the OP73 , TRASFER mode doesn’t change to START mode and when I select START mode , the OP73 it show Error.​
Do you think the problem from MPI cable or version OP73?​
because I have OP73 V 1.4.0.02.​
MPI cable(RS485) is : 3 to 3​
8 to 8​
5 to 5​
4 to 4​
FAQ
Procedure for transfer via S7 routing
http://support.automation.siemens.com/WW/view/en/21897528
How do you do an operating system update (OS update) on operator panels?
http://support.automation.siemens.com/WW/view/en/19701610
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,418
Hi, new member looking for help trying to understand why it is I have no problems going through hard wired electrical schematics, but struggle...
1,942
I'm starting a large project using a Beckhoff controller and I/O. Their modules are what I'd call the "slice" style, similar to Wago and others...
1,815
Hiya - Not specifically to do with PLC's but I have been doing a bit of autocad practise recently (ACE_14/15) I have conflicting information...
17
5,034
I have several Micro Logix 1200's that are bad. Looks like fine metal dust has gotten between the lower board and the plastic outer shell. There...
3,262
