TimothyMoulder
How much detail do you go into in your schematics?
I've seen schematics where every termination is labelled, every cable line is explicitly identified, and every wire in between is marked with a unique ID number.
On the other extreme, I've seen schematics where there is a line between output and solenoid, marked with the wire number, and any number of cables and plugs are simply ignored.
Some people seem to think the higher level of detail is overkill. Others think the lowest level of detail isn't helpful.
What do you guys think?
TM
TM
