Schneider ATV71 torque limiting problem
dcovemac
Jul 2011
Bruges Area
For a new application I'm experiencing some problems with my brand new ATV71
The drive is controlled in Torque limiting.
Sensorless flux vector control V
I sent a higher speed value then the application can manage so a steady torque should be applied. Everything seems to be working fine on lower speeds. Process value equals setpoint value of torque
Problem is however when speeding up at about 1200rpm's my torque drops 20% of the setpoint for no reason and stays at that value while still speeding up..
setpoint torque is only 20% of nominal torque so I don't believe it's current holding thing back here.
I don't find anything of such matter across the www nor in its prgramming manual. Does anyone have some experience here? thx!
no, this one, tla active
Schneider had to solve this one. They recognized the problem and could solve it by modifying hidden parameters based on the induction of the motor.
A solution for the wide public was promised in the next couple of months.
Hello all, Currently I am using a VSD ATV71 controlled by a schneider M340 with modbus TCP/IPusing IO scanning. For now i can start the motor and...
3,728
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
47
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
141
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
71
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
121
