Schneider BMENOC0301 Eth COM module
EddySch
Mar 2023
French Guyana
I have a Schneider M580 station equipped with a BMENOC0301 Ethernet COM module. The module is physically altered and we have decided to replace it with a new one, of identical reference.
After the replacement, should I upload the project for the new module to be functional? Or will the COM specs be automatically loaded?
Thank you.
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
136
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
69
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
111
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
198
