Schneider expert advice needed pleaseeeeee!!!
aamir baig
Aug 2011
jeddah
dear all,
i am having difficulty in getting my TWIDO (TWDLCAA40DRF) in communicating with my master gateway PLC QUANTUM 140 CPU 651 60 through connexium (Ethernet interface).
at my master PLC i have an NOE module 140 NOE 771 01 which is not scanning the inputs at the the TWIDO COntroller end.
SCHNEIDER EXPERT ADVICE NEEDED so that i can explain my system and come to a solution.
PLEAAASEEEEE HELPPPP!!!!
I don't know anything about the Twido but I have used the NOE modules on the Quantum. Can you post your Unity file? What about network settings...are the IP addresses / subnet masks setup correctly? A Wireshark trace would be helpful too, but if that is hard to get you can look at other things first.
you will need to setup the twido E/net port
there is a standard setup - top of me head cant remember.
look in twido suit manual - setup PLC and change e/net set up
OR you may need to modify port via the serial comms
thanks for the replies people
twido and quantum is communicating with the PC on individual basis through TWIDOSOFT and UNITY PRO respectively.but i want I/O scanning of twido I/O's in quantum through UNITY PRO.
twido controller----> connexium-----> NOE----> QUANTUM MODICON PLC
i want the exchange of data from right to left.
please help.....
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
153
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
85
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
176
Hi, I'm using Control Expert (a.k.a Unity Pro) to program M340 PLC. I am looking for a patch to fix what I think is a bug in PLC library. Please...
1,086
So i am developing a project on v8.1 The plc is a m340 I import my tag XSY file from the control expert software succesfully. Part of these tags...
1,738
