Schneider HMISCU
Simonw66
Jul 2022
Lincolnshire
I am a veteran PLC engineer, familiar with the AB PLC5, 5.02, then on to control logix. The Schneider HMISCU is fitted to a project we have been asked to support. I have a number of questions,
1. can you please confirm what software we need to program both the logic and HMI itself?
2. The client does not have a copy of the program installed, does the annotation live onboard the HMISCU, or if i upload will I just get the raw logic without comments?
Any support very much appreciated,
Thanks in advance, Simon
You will need ecostruxure machine expert software (formerly somachine)
The software is actually 2 softwares combined into one. The plc portion (machine expert) and vijeo designer for the hmi screens.
On the hmi side of things you will not be able to upload the software if a certain setting was not selected in vijeo designer.
Same applies for the plc side
HMISCU Schneider
Thanks for the response. Are you saying that if the previous programmer set some bits then the HMI and Logic are never retrievable! If so, time to rip it out and replace with something more supportable. You didn't answer my main question, do annotations, i.e. tags and labels/descriptions etc in the logic get downloaded with the code, are they unloadable? Many thanks,
Do HMISCUxB5 3.5 inch and 5.7 inch require same programming in vijeo designer or not. As when we configure HMISCUxB5 there is no option for selecting the size of HMI. Cn any anyone please guide?
I am at my wits end and hope someone can help. I am on a site with loads of the Schneider HMISCU units - my issue is that I can't download to the...
1,541
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
136
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
67
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
109
