Schneider M340 and Advantys
mjshaw90
May 2015
leicestershire
Hi all
I am trying to add new inputs to a remote island and when i use the file I have for the island it says the configeration is different when i connect to the island and if I update the config file it will not give me the listed tags for the inputs so if I load it back in to unity pro it removes all the previous tags.
Can anyone help please.
I have had the same issue in the past and don't know why!
I just resorted to not using the tag addressing feature, I just mapped my own tags to the memory location(s) that the IO scanner is using.
I think the integration of Advansys and Unity still needs some work....
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
141
so i have an isssue where if the serial port of an M340 plc disconnect from the screen it would retain the values of the variables being sent...
918
Hello, I'm having a hard time understanding how to get a Modicon M340 to pull a Modbus address from an ABB Totalflow via Ethernet. I set up a port...
1,159
Hello, this is a message for specialists in Schneider, I am trying to establish communication in modbus tcp between a schneider M340 (P3420302)...
1,615
I need to establish communication between Schneider M340 and S7-1500 PLC. I am using gateway converter for MODBUS TCP TO PROFINET protocol...
2,993
