Schneider M340 / Unity Pro - Analog Scaling
El Miguelo
Dec 2016
Darwin
Is it possible to scale the 4 to 20mA output of a Vegaflex 63 TDR Level Senor mounted on an inclined horizontal cylindrical diesel tank with domed torispherical ends, for volume in litres, by using the dipstick strapping table as a look up table in the M340 using Unity Pro?
I have tried numerous partially filled horizontal cylindrical tank with domed torispherical ends volume formulas but none seem to come close to the dipstick values. The closest I can get is with a 6th order polynomial formula derived from Excel LINEST function but do not know how to apply this to the 4 to 20mA value.
I also not sure of the best configuration of the Vegaflex 63 4 to 20mA output e.g. to use linearization and how to interface this to the PLC.
🤞🏻 Regards El
If you've got a formula that works, that can be easily implemented in unity using Structured Text. Just scale the 4-20mA and sensor to give you a reading in whatever units your dipstick uses.
I.e. if the dipstick is in metres with a max of 4m, then set up the the instrument to match and use a scale block to give you a real value in metres. Use this in the formula.
The dipstick tables are from 0.04 metres to 4.46 metres in 20mm increments from 4188 litres to 284,550 litres but the curve is not linear. We want the 4 to 20mA signal to indicate the litres in the tank.
yes you can use a table, first start with 2 points (that will give a line, then 3 points and so on until you have enough precision.
when whole table is in you have to use approximation, so find the lower value in the table and the higher one from the measured value. and then get the correct litres from it.
On ships this tables are in a book and for each angle they have separate tables. and factors for weight and temperature.
This give only 112 different litre values.
It isn't hard to configure Look up table with these values.
You can calculate approximation linearly from two closest values for level, if more accuracy is needed. (Or if you know exact values, you can add them directly to Look up table.)
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
136
so i have an isssue where if the serial port of an M340 plc disconnect from the screen it would retain the values of the variables being sent...
917
Hello, I'm having a hard time understanding how to get a Modicon M340 to pull a Modbus address from an ABB Totalflow via Ethernet. I set up a port...
1,155
Hello, this is a message for specialists in Schneider, I am trying to establish communication in modbus tcp between a schneider M340 (P3420302)...
1,612
I need to establish communication between Schneider M340 and S7-1500 PLC. I am using gateway converter for MODBUS TCP TO PROFINET protocol...
2,989
