Schneider-PM5320 Energy Meter Ethernet Communication With Rockwell PLC
prakasha
Dec 2022
Davangere, Karnataka, India
75
Hi All,
We are planning Establish communication between Power Energy Meter (Schneider PM5320) with Rockwell PLC. I am unable to get the Assembly instance Input size, Output size and Configuration size.. If anybody having idea on this Please drop a details here. if i get details that will be very helpful to complete my project. I wish to add as Ethernet generic Module
Thanks in advance
According to the PM5320 datasheet (https://www.se.com/au/en/product/download-pdf/METSEPM5320), that meter appears to only support Modbus/TCP and BACnet/IP protocols, not EtherNet/IP (which is why you won't be able to find Assembly details or use the Generic Ethernet Module).
You will need to either configure the Rockwell PLC to communicate Modbus/TCP (https://www.rockwellautomation.com/...d=modbus%20tcp%20client;activeTab=Sample_Code) or buy a gateway that can convert between EtherNet/IP and Modbus/TCP (or BACnet/IP).
Thank you for the reply..
Will you suggest me any latest meter which supports Ethernet with assembly instance details. Preferably I am looking for Siemens and Schneider meters.. I am greatful if I get right one to use.
Thanks in advanc
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
136
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
67
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
109
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
194
