Schneider TM221CE16R & SoMachine
If you use read/write blocks, then there is no need to select modbus mapping. M221 maps %M and %MW variables on behind automatically to modbus addresses.
Modbus mapping is for different configuration.
On master side you program write/read blocks according help files and block points with IDx number to partner PLC. (ID1 = slave 192.168.1.10).
You can have 16 different IDs on master side. (And slave IP addresses)
On slave side, you only need to give IP address and select enought %M and %MW variables to use.
(Default setting is that highest bit or word is highest uesd variable on program. On settings you can select that there is more variables, than you use on PLC program)
🍻 would be better (y)
If you have 1.5 Somachine, then you can also use IO scanner functionality for serial or communication blocks.
I have to get TM221M32TK - SL1 (Serial 1) to connect to their SCADA and SL2 - To HMI GTO 6310
i want to know how i can configure this? please direct me to the right way.
Thank You
I have to get TM221M32TK - SL1 (Serial 1) to connect to the SCADA and SL2 - To HMI GTO 6310
The data from the Tm221 port SL1 has to be collected at Mauritius, thats via network , is the module compatible for the purpose.
and which modbus is require rs485 or rs 232.
Thank You
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
47
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
141
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
71
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
121
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
200
