H5724 should be Unity processor (Hot standby PLC actually, mono or 2xPLC/Reduntant.)
H57 23 would be PL7 if not updated to Unity firmware.
By default comments and variables are saved to PLC on Unity / Control expert versions.
Setting can thought to be unchecked so that there is little bit more programming memory reserve. P57 and H57 PLCs taked pretty much memory on program side if they are compared to PL7 or newer M-range PLCs memorys.
USB port is your friend on this system. IP addresses are swapped between PLCs if they swap. You see only from Run led and on USB online connection if PLC is standby or Master PLC on system. Also making modifications needs to be done on right order.
