Schneider UnityPro S data type error
baselch0
Jul 2010
Basel
27
Hi All,
I'm facing an error defining a data type as byte to realize a simple counter......
here the ST code:
IF rst THEN
cnt:= 0;
Q0 := 0;
Q1 := 0;
Q2 := 0;
Q3 := 0;
Q4 := 0;
Q5 := 0;
Q6 := 0;
Q7 := 0;
ELSIF clk THEN
cnt:= cnt +1;
Q0 := cnt.0;
Q1 := cnt.1;
Q2 := cnt.2;
Q3 := cnt.3;
Q4 := cnt.4;
Q5 := cnt.5;
Q6 := cnt.6;
Q7 := cnt.7;
END_IF;
Compiling the code , system give the follow error refer to tag call cnt
E1092 different data type ('cnt:BYTE'<->'cnt + 1:ANY_NUM')
If define the tag cnt as INT then no problem to code compile.
Question is how is possible realize a counter using just a byte and not a word???
Thanks in advance
I had to do this:
cnt:= DINT_TO_BYTE((BYTE_TO_DINT(cnt) + 1));
Which is pretty messy.
Why not just work with INT or DINT types? Then there's no need to cast data types.
I think you can't do this because Unity treats the Byte data type as a bit string, not as a numerical value. From the help file:
Reminder Concerning Bit String Format
The particularity of this format is that all of its component bits do not represent a numerical value, but a combination of separate bits.
You are trying to add a number to bit string, so you get an error.
Thanks a lot guys for the answers,
about error E1092 different data type ('cnt:BYTE'<->'cnt + 1:ANY_NUM')
probably could be possible specify the tag "cnt" as ANY data type..........
regards and thank again
Hi friends I am unable to open a unity pro program which was done two years back for my client. the software version which i am using now is...
2,555
Dear Friends, I am using Schneider UNITY Pro XL Version 3.1 software with MODICON 140 CPU 65150. Recently we are facing a problem while going...
5,445
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
43
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
54
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
154
