Schneider Vijeo-Designer Script
nhadjinikolov
Dec 2010
Sofia
Hey guys!
I'm working on a Schneider 340 CPU and using the Vijeo Designer I have to make a trend graph change it's display range through some buttons. I tried to access the values as in an object-orientated language like this:
Code:
TrendGraph01.RangeSettings.DisplayRangeMin
But the code validator kept telling me "Error S8020: [Switch02: Script] [Line:7] Undeclared local variable "TrendGraph01"".
Can you give me a hint how to make it, if even possible :)
Thank you in advance! :)
Hello,
I do not have Vijeo in front of me so I am not exactly sure.
But in the properties for the diagram you can set the number of samples for the X-axis for the signals. Here you can choose either a fixed value or a variable. Declare a internal variable and use. In the buttons then you just set the value of the variable acording to how many samples.
Hello again!
Terribly sorry for the long delay...
I finally had some time to meddle with the Schneider display for which this manipulation is needed.
I needed to change on the go the range of the trend graph, not the samples per second, but I think that that's not that important.
I declared an internal variable and when I input it's name in the trend's property, it throws an error saying it's expecting a numeric value.
The strange thing is that when I try to modify the value you suggested - Number of samples, as soon as I enter the var name, it returns to the previous value without an error message this time...
Maybe I'm wrong somewhere, but I can't seem to find where exactly o_O
Any regular users of the magelis range? If so, anyone have a slick way to do a common popup with a rockwell UDT? My current approach is to just...
1,673
Hi guys, I installed new MachineExpert v1.2 and Vijeo 6.2.9 on Win10 machine. When connecting simulation PLC to Vijeo to test my application...
2,137
Hi, I was given a SoMachine application (PLC+HMI). I was asked to take the HMI portion and convert the addressing so it can work with a...
4,318
Hello Everyone. Simple question, is the V4.5.1 the latest version of the Vijeo stand alone data management tool? I ask this because: In Vijeo...
2,597
I've been tasked by my supervisor to make a connection and do some testing with Vijeo-Designer (Web Gate specifically) and a Magelis Touchscreen...
6,987
