SCL Siemens array question
vib
May 2022
spain
Hello,
When you want compare values of an array to a range of numbers is it a right way to do that?
Code:
FUNCTION ADD
  VAR_IN_OUT
     A:ARRAY[1..50] OF INT;
  END_VAR
  VAR_TEMP
    I:INT;
  END_VAR
  BEGIN
    I:=0;
  WHILE I<50  DO
    IF(A[I]:=1, 3, 7, 9, 12, 15, 20, 21, 14, 17, 30, 33, 36, 39, 42, 49 )THEN
       A[I]:=A[I]+12.5;
    END_IF
   I:=I+1
   END_WHILE
   ADD:=A[I];
END_FUNCTION
Or I have to check 1 per 1 value? I wanna know if you can check it like that
Oh dear .... anyway..
I dont have my programming pc at hand, but I think you can do it like this:
Code:
FOR i:=1 TO 50
  CASE A[i] OF
    1,3,7,9,12,14,15,17,20,21,33,36,39,42,49: // match found
  ELSE
    // match not found
  END_CASE ;
END_FOR ;
Code:
FOR i:=1 TO 50
  CASE A[i] OF
  ELSE
    // match not found
  END_CASE ;
END_FOR ;
Oh can you use CASE like that? using ELSE inside?
Sure, you can omit the ELSE part, but using it results in cleaner (more readable) code.
To make sure that you understood, it works so, that if any of the cases was not there then the else part is executed.
Hi All, I am currently writing a new function in SCL, And I have a array at 300 bytes (tmpArray[0..299] OF Bytes) to this function. Questions...
3,430
Hi All, I need to try and convert some code from Siemens SCL (TIA16) over to Allen Bradley RS5000. I have attached an image of the SCL and what...
4,061
in the scl code written in screenshot Line 1 condition is false but still the program checking the line 2 condition and says it is true i had...
1,762
I am new to PLC programming. Is there a standard way to incorporate alarms / warnings / events such as the exceptions in C++ or Java where you can...
1,986
Hello All, I am new to programming with Tia Portal and I am having difficulty with something that we have found "easy" in other programming...
2,381
