SE HMI not seeing the plc.
SMOKE
May 2006
East and West of Kaos
475
So I was called in Friday night a PLC was faulted. The fix was easy key reset. Have any of you guys made a message with FT SE to tell that there is no comms with the PLC?
Also I tried to connect to the PLC from home and Linx or a ping could not see it. I reset the PLC with the key so I don't know the fault.
Smoke
What kind of plc? Normally you can still go online to reset the fault unless it is a major hardware fault which may trump comms but i have never seen that happen.
Most of the time there is a no comms message in view se and me that indicated no comms but does not give a reason. AFAIK it is built in and does not need to be setup or configured.
There is a Tech Note on the AB/Rockwell Knowledgebase 55990 that talks about how to do this.
Was the Fault LED on solid, or flashing?
Stu....
Hello everyone, this is my first post on this forum but it's helped me in the past and hopefully it will help me now. I'm trying to get a first...
1,282
Hello, I am trying to setup communication to a Panelview 800 HMI Part No. 2711R-T4T in Connected Components Workbench 12.00 I am using a...
1,991
I'm having a hard time either remembering or figuring this out. I have a PLC program and the associated HMI program. I know what this means...
98
Hello, I'm working with Studio 5000 and ME Station, and I'm trying to find a way to detect if the PC with the HMI is shut down or not. I've tried...
138
Hello everyone, Wondering if anybody can help me with this: I have a CompactLogix processor running a little robot cell. Every 200 cycles...
158
