Search function in InTouch
zhphust
Dec 2004
Kobe,Japan
In InTouch, is there any method to get the list of where some string is used in the whole project? Now, only Tagname and QuickScript can be searched and I want to search other random strings.
Searching in InTouch has gotten better, but is still not up to what you are asking. In your case, finding a string, you will probably have to use the old fashioned search function.
First, create a "Generic Text Only" Printer on your system, and set it to print to FILE.
Then, Print out the entire InTouch project to that file.
Finally, open the text file in your favorite text editor (or notepad if that's all that's available) and search for the string there.
For the record, this used to be the only way to search for anything in InTouch, including tagname usage.
Good luck!
It do work
Thanks for a lot.
I printed the whole project to a text file and now I can search any string within that file.
By using it with InTouch's IDE together, I can read other people's program easily. :p
Good morning folks, I'm on a quest to find all of the references to the CurrentUserHasCode function in our project. I have the project...
430
Hi Guys, Is there a tag search function in RSView Studio similar to the old function that was available in Panelbuilder 32 where you could...
3,041
I have a difficult time finding inputs and outputs using CL5000 search. Most of the time I am dealing with inputs and outputs and don't know...
2,578
Hi all. Just wanted to call Phil to the attention that the integral search function seems to have gone unreliable. I mean the one in the tool...
1,883
Is there any way for RSLogix 5 to search for addresses that are located inside of Message or Block Transfer functions?
1,999
