Section Block Control in Parker DSE 890
Brad K
Nov 2012
Wisconsin
Can anyone help me invert the correction to the speed demand in the section control block. The drive's base speed is correct, however the correction to tension error is being applied in the wrong direction making low tension lower and high tension higher. I see the forward/Reverse selection but that only seems to invert the base speed, not the correction.
Thanks in advance
I'll take a stab at it. I don't have a drive to check it on though.
If you are NOT using the load cell inputs and you are using the FEEDBACK input, you need to subtract the feedback value from 100% before connecting it to the FEEDBACK input.
If you ARE using the load cell inputs, then I THINK you need to set the LC 1 ZERO and LC 2 ZERO to -100% and set the LC 1 SIGN and LC 2 SIGN to -100% also. Hopefully you are scaling the load cells or whatever before this block.
You need your feedback to range 100 to 0% rather than 0 to 100%.
This is one of the blocks that could use help in the help file.
The easiest way I know to do this is the change the extensible and non-extensible range values to negative numbers. The range values are direct multipliers to the PID section output so a negative value in these spots will invert the direction of the correction.
Keith
the easiest way i know to do this is the change the extensible and non-extensible range values to negative numbers. The range values are direct multipliers to the pid section output so a negative value in these spots will invert the direction of the correction.
Keith
+1
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
446
Hey everyone, In the middle of deciphering STL code in S7 plc and I'm confused. I interpret the following code to be load the register "#Step"...
2,069
Good afternoon all, What does FW and W mean in the picture below? Thanks,
2,334
I'm having an issue using the supplied PF52XUSB file to flash my programs. I was able to use it to flash the control section of my 525 drives...
3,047
I have tried unsuccessfully to list equipment to the Buy/Sell PLCS section. Anyone else having difficulty? I sent a note to the admin. but no...
1,497
