I can print what we have and do it on tuesday. I only have access to classroom and actual plc on tues & thurs. But tues is the last time. I can merely draw it on paper right as that what I have been doing as we been working through all this and reading inmy book and researching other topics and such.
If you download LogixPro Simulator from thelearningpit.com, you can run the Traffic Light Simulator and watch it run!
What would be my next step after MOV instruction in rung 2.
Make it almost a duplicate of the program I posted in Post #36, the typical traffic light using a sequencer. The only things different:
1. You have 9 steps instead of 6, so change the SQO Lenth from 6 to 9.
2. Your Outputs are in Slot 3 instead of 2, so change O:2 to O:3 in the SQO.
3. For Rung 001, add 3 more rung branches and change all of the EQU comparison "Source B" values to match the timer settings posted in Post #45.
4. For Rung 002, add 3 more rung branches and fill in with the appropriate B3:7 through B3:9 values that you figured out yourself (making a total of 9 rung branches, one for each of the 9 Steps).
5. You can change the Mask in the SQO instruction to 00FFh to allow only the lower 8 bits of the output to be controlled by the SQO. This is an optional change in this case.
Here is a a copy of the running program. Note that to run it in LogixPro, the Output must be Word 2, because that is the Output word that the LogixPro Traffic Light Simualtor uses. You can adjust it to run on your lab computer by change the "Dest" in the SQO instruction.
WARNING: This program does not have the added Input switches (AUTO, OFF, CHANGE) to do certain things required by your lab. I could not find out how exactly how those are supposed to work. You can probably add those to work with the sequencer. Basically you probably need to stop the sequencer (by stopping the Timer) and then manually set certain outputs as required.
