Security Login no Keyboard
the touchscreen is not relevant, the software has a log in function
that just pops up a small text enter window, but it will not cause
the pop up keyboard to open
Need a VBA function I think
it is PC based, and it does pop up when using a text entry
field, however the login function is a built in function
that does not pop up the virtual keyboard
RSVIEW32 Rockwell
Make and model
the computer is not relevant to the issue
any computer with any touch screen would run the
software the same way.
The problem is RSVIEW2's log in function is not geared
to-wards a touch screen.
So the question is how to get around the problem
hi i dunno about rsview but if you want auto login then i have created hmi buttons that force user names and passords into the 'active' ones for a cimplicity project. Did this on a system where the ops had to log on to run machine and it was a pain for them
Actually, it is relevant, you didn't bother to mention it was RSView before. Although it appears you have a typo, I presume you meant RSView32. We use it with touch screens, and it works fine. Create a button to login, and open an onscreen keyboard. There are ones you can download from AB/Rockwell Automation, or you can build your own using Sendkeys.
Stu....
On an Archestra system How can I have the username to hit The alarm page when the user logs in & out? The username hits the alarm page when they...
1,076
Suddenly, we have an issue with IFIX (v4.0). I don't know if any patches were pushed by IT (they say no, but...), but when a user tries to login...
22
9,553
One more guys, I have security setup for user groups and users,how or what can I do to create a log of who and what time date has loged in...
2,067
Hello Friends I have a backup that I am trying t open in mi PC (RSLogix 17.01) and I get this message. I have read many posts and done many...
189
After a recent revision of code in my system on both the HMI and the HC900 PLC, I now get a popup requesting me to login when I click on the...
525
