seimens micro master 420
What kind of load does the 420 run? Any digital (OFF2/3/ Jog..?) or analog input connected (internal pressure/flow/temp PID)?
If it is a 'simple' kind of load, you shouldn't need to bother about many of the parameters.
Check the 'cuick commissioning' chapter in the manual. There the most relevant parameters are listed.
How are the dip-switches of the profi module set? If all are 0, you'll find the node address in P918.
Kalle
micro 420
i went through and copied all of the parameters most of them are at default need to find out what software is needed to upload paramerters and then down load so that next time i will not spend so much time doing this
drivemonitor or starter usually free for download thru Siemens support but you will need an interface and cable 6SE6400 1PC00 0AA0
Or as described if you have an Advance keypad (AOP) it could save and load parameters set.
It is best to do a factory reset before downloading if the used drive isn't 100% brand new not used.
Be carefull if you do it mannually, few parameters have index that could use 3 differents configuration for 3 different modes or motors
opening up a copy of my HMI program I can go to where the passwords are created but they are all asterisks. How can I view what is there? I see...
1,104
I have installed ver 16 of tia portal and I am running in the 21 days grace period. My question is this, is it fully functional during that 21...
3,072
Hi; In our corrugator plant, there are one Corrugator and five Flexo graphic printing machines. One of them is a BOBST brand French made...
1,916
We have these in our shuttles. The IP Address is stored on the SD card for the unit. We had a card go bad and I am trying to copy another card...
1,159
Good morning, experts! I have a Siemens PLC and IO that I need to cross to Rockwell, and I have zero experience with the Siemens line of products...
1,555
