seimens
ajay34
May 2010
klang
249
i having problem to connect between PC and S7 cpu.model 3132c.
using wincc 2008 to operate system via pc..
my connection was from CP 5611 thru Profibus connector to PLC.
i was unable to connect with plc..there was error msg ..bus faulty..i
i had try swap connection between (on profibus connector ) and set PG setting as well.
i do try connect to MPI/PROFBUS still unable to ..
can any 1 hint what may i lack seeing it
It may seem too obvious but have you checked the position of the on-off switch on the profibus connectors? Sometimes those switches change position too easily..
Port and profibus connections ok on the PC? i.e. same baud rate as the PLC has and same profile eg. DP / Universal etc??
Has this worked previously and suddenly stopped working or is this a new installation?
this wat i get when try diagonistic hardware (this can be seen on set pg/pc ) and when i click the hardware and test result ok..led flashing when i test it..
Error 0x031b: Synchronization error (problems with the PROFIBUS network)
this was working previously until again the pc broke down and install wincc 2008 sp3 and step7 5.5
opening up a copy of my HMI program I can go to where the passwords are created but they are all asterisks. How can I view what is there? I see...
1,104
I have installed ver 16 of tia portal and I am running in the 21 days grace period. My question is this, is it fully functional during that 21...
3,087
Hi; In our corrugator plant, there are one Corrugator and five Flexo graphic printing machines. One of them is a BOBST brand French made...
1,923
We have these in our shuttles. The IP Address is stored on the SD card for the unit. We had a card go bad and I am trying to copy another card...
1,168
Good morning, experts! I have a Siemens PLC and IO that I need to cross to Rockwell, and I have zero experience with the Siemens line of products...
1,557
