SEL3530 Modbus Server Question
timcph2008
Jul 2015
United State
33
Hello guys,
Did you set up a SEL3530 Modbus Server before?
Suppose a Modbus TCP server can process request from multiple client, right?
However from the SEL3530 manual it said
Which means I can only talk to 1 client? Does anyone have experience can share?
Also how do I setup the slave ID? I am thinking to create multiple modbus server in a SEL3530, If the a modbus server only talk to a client. Is this possible?
Thank you!
However, I found that the way to setup "Slave ID" is the IP port number.
I can set up 2 Modbus Slave, Slave A and Slave B,
2 Modbus Master, Master A and Master B
Master A write the data to Server A register
use tag processor to transfer that register value to Server B register.
Then used Master B read the Server B register.
However, in this case I need to know how many Master is in the network...
I tried to connect multiple master to same slave but I cannot... Only 1 at a time...Still looking for if that possible
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
29
61
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
240
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
178
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
