SEL3530 Modbus Server Question
timcph2008
Jul 2015
United State
33
Hello guys,
Did you set up a SEL3530 Modbus Server before?
Suppose a Modbus TCP server can process request from multiple client, right?
However from the SEL3530 manual it said
Which means I can only talk to 1 client? Does anyone have experience can share?
Also how do I setup the slave ID? I am thinking to create multiple modbus server in a SEL3530, If the a modbus server only talk to a client. Is this possible?
Thank you!
However, I found that the way to setup "Slave ID" is the IP port number.
I can set up 2 Modbus Slave, Slave A and Slave B,
2 Modbus Master, Master A and Master B
Master A write the data to Server A register
use tag processor to transfer that register value to Server B register.
Then used Master B read the Server B register.
However, in this case I need to know how many Master is in the network...
I tried to connect multiple master to same slave but I cannot... Only 1 at a time...Still looking for if that possible
Hey all, I am working on a project and i want to use Allen Bradley Micro850 controllers. This model has ethernet ip functionality. So the project...
25
Hello, fellow PLC enthusiasts, I’m a newbie in PLC and am currently on a project that involves connecting an Omron CP1E (CP1W-CIF11) PLC to an...
55
I am new to this forum and would need your help. I am looking for the Modbus FBs for the S5 95U for communication with the CP521. These FBs...
32
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
152
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
104
