Send Messages to a PLC through UDP
dconstan
Feb 2004
Markham
I build a program in VB.net that reads network packets coming from an Omron PLC. What the program does is gather these packets, then it Filter them to get the text messages, and then it stores the information in SQL server. The reason for this exercise is to gather Faults and other problems with the PLC for later reporting and preventative maintenance. But now I need to be able to tell the PLC that I received the packet so it can proceed, and if I do not send back a response in 3 seconds lets say, it should send back the same error to the PC, it tries this 3 times then it quits and proceed.
SO I need to know how can I send a packet to the PLC? Where do I send the packet to? what should I send.
PLC CS1G
VB.Net
UDP Protocol
Regards,
Danny
Hello, I'm trying to use the CJ2W-CPU32, westermo MRD 315 to send messages in case of problems to the operators. Where should I configure the...
2,613
Folks, I just joined the forum ! Please suggest/advice about possible options for receiving event notifications over text messages on a CDMA...
3,095
HI guys this is my first post I just started using the RS5000 I have used the rs500 for 12 years, and we build automated fixtures, we have always...
4,718
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
can the slc500 5/05 send a email and text over Ethernet ?
188
