Sending a print screen to multiple locations with Siemens HMI
Walks
Jun 2018
Midwest
47
Hi, I'm curious if anyone knows of a way to print a PDF from a Siemens Comfort Panel HMI to multiple locations.
I can print a PDF to a single computer or USB drive using a print screen button on the Comfort Panel runtime application without a problem. I've gone through the Siemens documentation on printing from an HMI and it appears that they only allow you to print to one device by default.
Is it maybe possible to write a script that can send the PDF to multiple locations?
I found info on the Siemens forum but it doesn't appear to work.https://support.industry.siemens.com/tf//WW/en/posts/printing-on-multiple-printers/42245?page=0&pageSize=10
In theory, you should be able to write a VB script to copy the file from one location to other locations. I'm not familiar with the system hooks you'd use for this, but if I recall they are different between the panel based (windows CE) and PC based (windows 7/10/etc) runtimes.
Hi, I'm curious if anyone knows of a way to print a PDF from a Siemens Comfort Panel HMI to multiple locations. I can print a PDF to a single...
2,274
I am using a compactlogix 1769-L16ER BB1B to send a print string to a L-series Mathew printer. My main question is can I setup a TCP/IP...
1,856
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
90
Hi I need to send a null command down a comms port. But in the crimson software when i used /x00 it coming back "Cannot use null character is...
422
I've been having some trouble figuring out how to get the ip address for the mail relay server, is it something that I need to create separately...
915
