Sending string from 5/05 to server
saturnme
Sep 2005
Davison, Michigan
Does anyone know the best method for sending a data string from an Allen Bradley slc 5/05 to a server. I have a data string located in a ST file that I need to send through channel 1 (ethernet) to a local server.
I also have several applications where I am trying to send data from a slc 5/04 to the same server. On the 5/04's I have devicenet installed and I am currently looking at different devicenet to ethernet gateways. Is this the best method for getting the data from the plc to the server?
I am using a compactlogix 1769-L16ER BB1B to send a print string to a L-series Mathew printer. My main question is can I setup a TCP/IP...
1,862
Hello everyone, what I am trying to do is import a specific string directly into a cell in an excel sheet. I have been using the Copy DDE/OPC link...
3,245
Anyone know how to receive the string (UPC Code) from a dataman 302 (Cognex) to a SLC 5/05. I need to be able to retrieve this code, and I am...
1,884
Hi, I have a retrofit enhancement on an existing PV1000 (Not PV +). It is a 2711-T10C10 with a RS232 port and DeviceNET. I need to send a string...
2,850
I would like to send a simple ASCII string from a PanelView 550 Printer port with a button press. String Sample: ABCDF 1 Any Ideas?
3,623
