Sensor for solids not liquids
rigicon
Aug 2009
kent
415
Any one have a idea about a sensor for solids but not liquids.
Coming out of a pipe is a solid "bullet" and then jets of water.
Want to sense the bullet made of steel & plastic but not the water.
was thinking about a light barrier mounted in a frame. ???:unsure::confused::confused:
Hi Rigicon, what type and color is the plastic? Is it very opaque? I wonder if one of these new low-cost Vision Sensors would be appropriate for this application with a backlight? Something like this...
http://www.bannerengineering.com/en...ision-Sensors/503/iVu-Series-TG-Image-Sensor/
Perhaps overkill, let us know about the plastic, that will be the key to picking something that can "burn through" the water without burning through the plastic.
Prox won't work if he wants to detect plastic. The OP can clarify, but my read is he wants: Plastic and Metal ON, Water and everything else OFF, is that correct, rigicon?
The "bullet is made with steel and a plastic outer covering".
The water shoots the bullet along cleaning as it goes. If it gets stuck the water can get past so Don't want to sense liquid(water) just the bullet.
Camera seemed good idea but constantly programming it, that's why I thought of light guards.
What are the dimensions of the bullet?
What is the estimated velocity of the bullet?
How about a metal detector?
Or, perhaps a pressure switch to detect a "jam"?
Endress and Hauser in the UK, not cheap but superb products and support.
They probably do something.
We detect solids in a vacuum pipe of an extruder with a thermocouple (either J or Infra Red), the solid is generally a lot hotter than the vapour. Worked well for our appliaction, customer now has them on all extruder.
Cant see why a plain ordinary prox wont work.
Stainless steel is not so easy to detect on as normal steel, but not impossible at all.
It is cheap, does not need cleaning, does not need programming, can be mounted flush or virtually flush with the pipe.
What's not to like ?
Is there something we have not been told ?
An ordinary prox would be terrific. I apologise to the forum for not mentioning that the tubes are steel been.
Sorted A circular prox at the end of the pipe I only had half the story myself. Was under the impression that we had to read it in the pipe. Simple Thanks to the forum. You guys are the bee's knees. Cheers esp JesperMP & SMOKE.
Does anyone have experience using a TDS (Total Dissolved Sensor) w/ a PLC analog input. I have a customer trying to move from a control box and...
11,551
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
90
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
120
Hi, Need help with coding for a faulty component sensor which we are using a push button as we are using a test rig. the plc is a allen bradley...
224
Hi all, I am implementing an incremental encoder sensor (ABZ) to replace the existing "manual" encoder wheel I have in my device. This is a 360...
176
