Chilltrans
I got a sg2-20 controller to handle operating a few relays on a machine I am building/modifying.
I'm new to ladder logic but not programming. I've got the basics and not much more.
The machine I am controlling extends pneumatic rods into a barrel, which is shaped very much like a revolver. The barrel houses 4 cylinders, and is turned, pneumatically via 24 volt relays.
There are sensors at both limits of the rod's travel for all 4 rods.
The cylinder turns pneumatically by activation of a relay, and enters the loading position when the relay is deactivated.
There is a sensor that verifies the cylinder is in a loading position. This sensor will switch off as the revolving cylinders moves. It will switch back on as the barrel is in a loading position.
My problem is in how to sequence the moving of theses rods in conjunction with the cylinder turning..
The process is as follows:
Verify all rods are in retracted position
Verify barrel is in parked position
Energize rotation of barrel solenoid
Verify barrel has moved away from parked position
De-energize barrel solenoid
Energize wrapper injector
Verify injector extended
De energize wrapper injector
Verify injector retracted
Extend candy fill #1 injector
Verify extended
De energize #2
Verify retracted
Etcetera for candy fill #2 injector
And a final wrapper injection
Go back to beginning and start over
Any and all suggestions would be appreciated as I don't have the experience to do this without some help. I've been at it a few days, and realize that this ladder logic is a little different than the programming I have learned....
Verify extended
De energize #2
Verify retracted
