Serial Cable Festooning
craven8283
Aug 2017
Indiana
Im working on setting up a 2D barcode reader with a RS 232 cable back to the PLC. An engineer is requesting they want the bar code reader on a mobile station (back and forth Movement)? Im against this due to the serial cable movement (lifespan). I would like the reader to have a fixed position. What are your thoughts on festooning the cable?
Igus (and others) make motion rated serial cables. I prefer a cattrack or similar installation to festoon, but I've done that before. Obviously you want to eliminate potential sources of mechanical wearing (rubbing, pinching, etc.) but it's not uncommon to have serial cables in mobile applications.
Either way will work just plan ahead
I would recommend using a flat doubled shielded festoon cable
not the standard round shielded cable ( they don't last long in a festoon)
I have run them without any problems
the other issue is how are you planning moving the Barcode reader the moving reader is a lot more complicated and will a lot of planning to make it work
Do the Horner adapter RS 232 to snp adapter could work on that plc to go online with my laptop and Proficy ? HE693SNP232A with a IC200CBL001A I...
1,981
Hey all, I know this is a shot in the dark: I'm trying to setup a redundant pair of ACM controllers and I dont have any of the serial cables for...
1,155
Good Morning , I just purchased a Windows 10 Hp Laptop. Of course no serial ports , but 3 USB ports . Need a USB to Serial cable to go to...
20
6,237
Hello, Does anyone have the Triconex Tristation serial cable pinout? The cable part number is 1600080-0xx.
1,152
So I am happily communicating with my CPE305 at its default, out of the box IP Address of 192.168.0.100. So now I want to download a new project...
5,764
