Serial to Devicenet Convertor
TCuts
Sep 2003
Hi All,
Does anyone here know of a device which will let me attach a serial hand scanner to devicenet? Obviously it would have to have some smarts in it for node addressing etc. I can't seem to find a device like this. Any help would be appreciated.
Thad
I've used DIP Inc's CDN-066 as well as WRC's 1782-JDC device. Both work fine once you figure out how they're using a DeviceNet I/O image to represent a stream of serial characters.
If your master device is an A-B scanner there are detailed configuration examples available for both of those products.
Hi all, Firstly sorry this is so long winded, but at least you get a solid background. Can anyone help with a problem I have with a Device Net...
4,987
Hi all can I connect a barcode scanner with a 1761 net-dni to a logix processor over devicenet network or is there a alternative.
1,490
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
202
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
199
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
341
