Server busy
BOBN
Aug 2008
UNION, KY
When opening an instance of RS500, I am now getting a error message block that reads;
"SERVER BUSY
This action cannot be completed because the other program is busy. choose switch to, to activate the busy program and correct the problem."
This started all of a sudden. I have been using this program and laptop for several years. When I hit the "switch to" button, it opens up the start menu. If I hit the "retry" button, nothing happens. Sometimes I just keep trying and it will clear. I have no other programs open. I even take it off of the wireless and hardwire networks.
Tech support says to open up task manager and clear the program. When I do this, I don't have a program to work with. Any help would be appreciated.
Are you just simply opening a project or trying to go online? What version of Logix500 do you have?
You could try deleting the harmony files from C:\Program Files\Rockwell Software\RSCOMMON
Also try opening the software while holding down ctrl and shift on start-up.
I keep getting this error when I open it and the I have to Cntl-Alt-Delete to get out of it. I also have FTVS-ME installed but I even rebooted...
7,949
This error is inconsistent. Most of the time I try to open RSLogix500 it gives me the error along the lines of "Server busy, action cannot be...
19,150
I'm running an ME Station on a PC, and when I try to load the .mer on PC startup, I get a "server busy" dialog box. I have attempted to apply the...
3,259
hi everyone, i have problem regarding Audit in FTV ver 12,In audit message "service disruption:<HMI server name>:<SERVICE NAME>" message logged,i...
51
