Servo Application
swayne76
Jan 2012
ohio
43
Hello All,
I inherited an application involving a kinetix 5500 2198 H008 ERS servo drive and a compact logix processor that will be used for a simple positioning application. I have little experience with servo programming. I was going through the parts that were ordered before I became involved and they had ordered a 1769-L24ER-QBFC1B processor as the controller. The little experience I do have are with the "m" processors and using studio 5000 to set up the drive. My question is, is it possible to use the above processor in this application and where would one start?
To the best of my knowledge the K5500 must be controlled as a "motion drive", which would require the M variant of the controller. I don't think there is a way to define the K5500 simply as an Ethernet/IP drop and control is similarly to a PF755.
Keith
I'm in the midst of a Kinetix 5500 on Ethernet/IP and you have to set it up as a CIP Axis. You of course set the CPU as the time master and the ethernet card has to also be set up to time sync as well. I'm away from work for a few days so don't specifically recall all the settings.
Hello Everyone. I need some advice on how to control a servo drive with a laser displacement sensor (SICK or Keyence). There will be an X and Z...
2,027
This is a question for anybody out there who has an in depth understanding of AC motors and how they work with VFDs, particularly in a...
3,887
I need some advice on servo drive systems. Here is the situation, I have a machine that I already upgraded to a Micrologix1400 PLC and is working...
1,646
I'm fairly new to dealing with servo motion but I have a fairly simple application I was hoping to get some feedback on. I've got a large load I...
4,640
I would like to get some suggestions from people on this board more knowledgeable than me about servos. I currently build a line of...
20
7,568
