JRoss
This is a question for anybody out there who has an in depth understanding of AC motors and how they work with VFDs, particularly in a multi-motor application. I'm putting this in the General Topics forum even though we're using Mitsubishi equipment because the problem is related more to the motors than anything.
I'm working on a job upgrading the drives on a massive pavement testing rig. The rig weighs in the realm of 1.4 million pounds, and rides on two parallel railroad tracks that straddle the testing area. The rig moves up and down the tracks on 16 sets of "bogeys" (8 per track) that are each driven by a 50HP constant torque motor. The motors are connected in groups of four to 350HP VFDs (total of four VFDs). Originally, There was an encoder on one of the motors that was split out to all four drives (for speed feedback) and the PLC (for position feedback). Moving the rig involved turning on all four drives with the same speed and direction; stopping involved pneumatic disk brakes on each bogey. The system is 12-15 years old.
The upgrade replaced the original Mitsubishi drives with Mitsubishi A700 VFDs (the most advanced VFD line they make) of the same size, as well as adding braking resistors to use "dynamic braking" and save the disk brakes for emergencies. In addition, we sought to improve the system by adding three encoders, for a total of four. Now each group of motors has its own encoder going back to its own VFD for speed regulation. For a variety of reasons, we took this a step further by adding motion option cards to the drives so that we could also close the position loop and control the system similar to servo. We had to send three motors back to the motor OEM to add extended shafts for the encoders. The customer also chose to have their spare motor modified in the same way (total of four motors modified).
After some initial difficulty tuning the system due to mechanical backlash, we had the system running fairly well. We took several weeks off while some other work was being done in the area, and then the fun began. After sitting idle for a couple of weeks, the customer powered up the rig to move it to a different section of the track. It got about 10 feet at a fairly slow speed, when one of the encoder motors failed catastrophically. Sparks, smoke, the whole nine yards. We came in and helped them mount the spare, then moved the rig about 4 feet to test motion. All was well, so we started to move again, and got a Ground Fault error on one of the drives. Turns out that a second encoder motor (NOT the spare) had failed, though very quietly. At this point, we megged all the motors, and found that most of them had more than adequate insulation (including the spare). However, a third encoder motor was nearly ready to fail, measuring at about 0.05 megaohms. I'm told readings should be in the 4-5 megaohm range. The three failed (or almost) motors were the ones that had been modified by the OEM.
So now we are facing the unenviable task of trying to figure out why the motors failed. One theory is that something happened during the modification to damage the insulation, and the OEM has all three motors and is trying to determine that.
A second theory is that something about the design of the upgrade is damaging the motors, and this is the one I'd like input on. Other than that, I'm not entirely sure what questions to ask. Any help would be appreciated!
I will also be posting this on the MrPLC forums.
