servo for compression
irondesk40
Jan 2008
nc
630
have a question that I hope someone may have a answer to.
We have quite a bit of compression type equipment, not very large, they are around 10-20 tons each.
At the moment, they use hydraulic cylinders, pumps etc.
Has anyone every done a compression type operation using a servo motor or electric motor? If so, could you possibly give some suggestions.
All of these units are controlled with micrologix 1100 plc's, and have plently of extra I/O points.
thanks
The latest and greatest injection molding presses are all "electric" or servo driven. No hydraulic oil on the floor and quiet. When I saw one run about 5 years ago I was really impressed.
You didn't mention your product but you may be on to something.
Servo Motor controlling a Ball Screw with a sufficient gear ratio to give you the required force. You can tell the servo to move to a position or a current level (ralative to force). If you network your servo you will not need the I/O
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
104
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
123
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
112
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
81
Hi, I'm thinking about using commands for Melservo J5 controller via HMI without PLC. Have you guys done this kind of control configuration for...
163
