Servo holding brake question
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all. I have retro-fit new servo amps and motors into an ancient machine. I am accustomed to using 24VDC from a switching PSU to energize and release a servo motor brake. On this unit, they feed the brake with a bridge rectifier, no filter. I am by no means an expert with servo systems so my question is, why would someone energize the holding brake this way? Thank you
Old School & Cheaper. The Servo Motor likely has a 24vdc brake. A small transformer and bridge should be cheaper than a full power supply. BUT, in today's market, with 1000's of cheap little power supplies being made, the power supply may actually win the cost + labor total.
Thanks guys. My only concern is the fact that it has no filter of any kind. I just don't want the ripple to wreck my brake coil. I guess as long as the mean voltage isn't allowed to drop too low, it won't notice a difference.
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
74
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
104
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
93
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
69
Hi, I'm thinking about using commands for Melservo J5 controller via HMI without PLC. Have you guys done this kind of control configuration for...
140
