servo motor tuning problem?
mike_dr
Sep 2011
Mla
215
Im using ultraware 5000 drive w/ MPL-A4540C-M servo motor. I cannot pinpoint the cause of the problem.
I built an program break.exe which stops the servo using Jogstop command when a sensor turns on but the servo did not stop. When sensor is off,it follows the speed of conveyor. I tried velocity regulator gains P=240, I=10, FF=1 it to lessen error sum (around 4000 counts/sec). just posted keypoints of the code.
#define SYNCSPEED_CH 1
#define OVEN_SENSOR 2
Move_Acc=600;
Move_Dec=3600;
Jog_Acc=600;
Jog_Dec=6000;
if (InputGetState(OVEN_SENSOR) == ON){
JogStop();
AxisDefinePos(0);
MoveSetAcc(Move_Acc);
MoveSetDec(Move_Dec);
MoveSetVel(Move_Speed);
MoveIncremental(Move_Distance);
while (InputGetState(OVEN_SENSOR) == ON);
if ((InputGetState(OVEN_SENSOR) == OFF)){
MoveAbort();
JogSetVel(Jog_Speed);
JogSetAcc(Jog_Acc);
JogSetDec(Jog_Dec);
JogForward();
I always thought that it's a good idea to tune a new servo motor but some people at work doesn't think so. We recently had to replace a bad servo...
1,865
I am autotuning a servo motor (with Kinetix 300) using Motionview Onboard. #1) About autotuing's travel limit. I don't know what it is. When...
2,290
Hi all, New here and new all round to PLC`s. We have a servo drive that runs a cross travel beam backwards and forwards. I am having trouble with...
201
My servo motor instruction is not being executed on the gx works 3 even after the positioning parameters have been set
125
Hi All. I am setting up an Omron 1S Servo Motor to drive a conveyor. It goes forward 200mm, pauses and repeats until it is stopped. However...
751
