laci1
Guest
L
Hi to All,
Need offer for solution and manufacturer name.
I like to found a solution to drive 5 servo motors for a glue insert machine.
Two motors have to work in an "x", "y" table and have to make
different forms like square, circle an more kind of forms not only exact
geometry things. To program the form has to be as simple as possible.
The other three motors work in "z" direction and need to be contact with the
speed of the "x", "y" forming to have the same same speed always like for
example in the corner of square where the speed goes to 0 also have to
make slow the "z" speed.
The Omron offer for this solution's price is expensive so I have to found
other solution. Thanks in advance if you have an idea about it.
Thanks in advance if you have idea about.
Best regards,
Laci1
Best regards,
Laci1
