Servo shaking problem.
JoeM1
Jul 2015
Tucson
71
Ok, now onto the next step in recommissioning the winder. This winder has three servos that are supposed to spin slowly to a certain point when you hit "origin return" (essentially a home from what little docs there are on this machine.)
Instead of doing this they oscillate back and forth without ever making a full revolution. Eventually Error 414 is displayed on the handheld.
Can somebody point me in the right direction regarding the relevant parameters I need to be studying?
These are "red cap" servos BTW, the controller is a PowerMate H
Thanks in Advance
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
103
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
121
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
111
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
81
Hi, I'm thinking about using commands for Melservo J5 controller via HMI without PLC. Have you guys done this kind of control configuration for...
160
