Servos and Kinetix 6500
Andres P
Jul 2017
Galicia
Good morning,
I have 4 kinetix 6500 and 4 servos MPM-B1653C-MJ74AA. I have them all on stopped status, and I am using Motion Direct Commands to move them, but i'm having several problems with them.
The MDC that I use when in stopped status are: MSO->Goes to Running Status->MAM->Starts moving with an incredible intense noise (like if its stopped by the breaks at least partially)->MAS->It stops the motion, but the noise stills and even more intense->MSF (the noise dissapears and goes to Stopped)
That is the same for the 4, but each has particular problems:
servo1: This one can move, stop, and change speed(fast and slow), even though the intense noise is there (and varies depending on speed and accel/decel) but with less than 5 min of use, it was super hot and finally an overtemp error appear.
servo2: with the same speed the first one did well, this one does not. with very little speed it can moves a little bit, but eventually an S55 error appears (excessive velocity error)
servo3: when it starts moving, in about 10 seconds maximum, it appears the FLT S13 and FLT S14 (inverter thermal overload factory limit / inverter thermal overload user limit), and also appeared the S55 error
servo4: much like servo3
Any tips would be greatly appreciated
Andres
Hola amigo, muy generico tu informe, haslo mas explicito, tiene carga o no?, como esta la configuracion en el software?, etc
Hi Andres.
Have you performed an Auto-Tune on all the above axis?
Have you parameterized the motion axis correctly? Ie mechanical drive, gearing ratio etc etc?
Are your brakes energizing correctly? Do you have sufficient voltage?, the first system I worked on had the brake wiring wrong and was actually running for 4/5 mins until the motor tripped on thermals.
I have 2 servos that is moving a gantry. I am planning to use one to follow the other using an MAPC command, but when I home, could I tie the home...
1,385
Good Afternoon , I have a machine that has 7 - Kinetix 6000 servos on it . All the servos want to run high speed and cannot slow down...
2,157
I have the new servos up and communicating. Will the tag names in the motion group be the same or are there new tag names associated with the new...
1,953
Hello All: First I hope that Kinetix servo questions are still on topic. If not can someone point me in the right direction? So I have just...
3,278
I have a unique project and will be commissioning it next week. It involves two servos that are both connected to the same belt in an H-type...
22
14,138
