Set a TIME in S7
apolionman
Nov 2013
Dubai
47
Hello again experts,
I am making a program in Simatic Manager integrated with WinCC flex. So here's my question: How can I set Time to the S_PULSE ? for example I have a text list :
1.) 1 Minute
2.) 2 Minutes
3.) 3 Minutes
When I select 1 Minute, S_PULSE will start counting 1 Minute.
Please help.
Thanks in advance 📚📚
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
34
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
337
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
105
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
88
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
92
