Set an IP of ML1200 through Ethernet Module
gibson
Sep 2012
mumbai
46
Hello,
In my project work i am Connecting two Allen-Bradley HMIs (PanelView Component C600 and PanelView Component C1000) to Allen-Bradley PLC (Micrologix 1200). As ML1200 doesn't have an Ethernet port i have used 1761-NET-ENI module for DF-1 to Ethernet/IP conversion also in between two HMIs i have incorporated a Switch. I just want to know how can i Configure the IP address of ML1200 through Ethernet module or is it require to configure it ? I have connected Ethernet module to PROG/HMI port instead of COM port (channel 0),Can i use this configuration ? :site:
You are not doing anything with the IP address of the MLX1200. This is still using the DF1 protocol using its COM port. The IP address is set inside the NET-ENI module. That is what is seen by the outside world (your 2 HMI boxes).
I am not sure what exactly you are trying to do. If you are using the HMI's to talk to the MLX1200, you don't need to do anything. They will do the job of initiating commuincation.
You will set the HMI drivers to match the configuration of the NET module. The MLX1200 is essentially blind to it.
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
17
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
88
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
76
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
81
