set daynamic value(variable) in LG plc timer
reza.akbari
Apr 2015
mashad
hello to all
I have a HMI and in this HMI I have numeric entry that I inter value.
and in the gmwin I have a timer(TON) that at PT part I want to set the value that I entered in hmi!
indeed I dont want to use static value in pt part of timer like t#20s
thanks for your attention
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
28
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
313
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
93
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
78
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
84
