Set FactoryTalkView SE time from ControlLogix
pr_wainwright
Jun 2011
Stockton on Tees
109
I have an application which is required to use the Rockwell 'SNTP Query & Clock Sync Instruction' (AOI) in a ControlLogix processor (Retrieves the current time from an NTP Server). The application also has a FTV SE project running on a Windows XP PC. How can I sync the time for the FTV SE project from the ControlLogix controller?
Paul.
Also note that there is a "Logix Clock Update Tool" that is a stand alone app that was probably installed with some other Rockwell programs; Run that on the HMI PC, and schedule it to update the PLC time automatically if you are concerned about the PLC time drifting.
rdrast,
The clock update tool updates from PC time to PLC time, I wish to sync the other way around. Ideally get the PLC time from the controller & set the PC time to the same. But as you have suggested I will need to use the time server for both PLC & PC.
Paul.
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
21
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
88
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
76
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
81
