Setting a tag to the USB port on PV800
Ckoch
Jun 2023
Ohio
I have a USB port RFID Scanner I am using for badging users into certain access levels in an HMI. I know that I could create a 'login' button that ties to a tag and have certain visibility attached to that. But, I was wondering if there is anyway I could have a tag automatically update if a badge is scanned (Not require a button press to login). Basically, just have a tag that views any USB input at any time?
I am using CCW and a PV800; My RFID Scanner is essentially a USB Keyboard
You can place a string entry on the screen and tie it to a function key. The keyboard would need to be programmed to send the function key before the badge data. Not sure what you would do with it after that.
+1
You can assign function keys to individual buttons, including a login button.
What RFID reader are you using? If you have the ability to configure exactly what ASCII characters are being sent whenever a badge is scanned, you can likely automate the process to where no button presses are required whatsoever, for one or two-factor logins. Works well on PVP6/7, haven't implemented on a PV800 but all the key functionality seems to be there. Again, somewhat depends on what badge reader you use and its capabilities.
Thanks everyone! I was able to add a function key as a pre data delimiter and that worked, thanks.
Hey! I'm looking for a way to reset a tag when the routine that sets the tag is disabled. For example: Routine 1 has the following If Tag1...
1,813
So I am currently trying to create a data-viewer within FT View. I need the operator to be able to select two different datasets from a list of...
1,315
Hi experts! As always I come seeking your expert advice once more I need help using Adroit, specifically trying to use databases I have a...
2,103
You are probably confused on what I actually want from the title, so here's an explanation. Right now I have 3 objects: 1: current value (read...
3,236
Greetings In our plant we use a ControlLogix5563 as our main data handling PLC. Recently I noticed that the controller date/time setting differs...
4,171
